750 whp exhaust setup
Old 03-03-2015, 06:59 PM
yellabella's Avatar
Default 750 whp exhaust setup
I have a 98 ta I am installing a 6.0, 4l80e, d1sc procharger on and I am looking for ideas on exhaust. I was thinking 1 7/8 tsp headers-catted tsp y-pipe-magnaflow catback. my only concern is that it will rob power not running true duals, but I dont want to spend 2k and I dont really want dumps before the rear. any ideas or thoughts on the setup I came up with?
Thanks
Old 03-03-2015, 07:08 PM
SmokedOutZ28's Avatar
I think most people in your situation run a catback with a cutout dumped before the rear tire. Instead of duals you could also try a 4'' exhaust.
In about a month I will be switching to kooks duals to see how I like them.
Old 03-03-2015, 07:24 PM
dckmn52's Avatar
Go 4" or larger.
4.25 would do it. Not going to say its more difficult to fit over the rear differential though. UMI makes a kit that gives you more clearance running exhaust over the rear diff. BMR may make one as well.
Y pipe setup will definitely make power. Lots of guys running X pipes that ditch to a Y make even more power, although that isnt surprising considering most X pipe setups are poorly designed and optimized.
Here is mine for an example:
https://ls1tech.com/forums/generatio...-ford-9-a.html
Old 03-03-2015, 07:38 PM
Cold Zero's Avatar
Do the Patrick G Y-Pipe
- Get Flowmaster Y-Merge (3" inlet/4" Outlet)
- Install 4" Cutout
- Reducer back to your nice 3" Magnaflow Cat-Back
Old 03-03-2015, 08:48 PM
BlackDuk98's Avatar
What Cold Zero said. The link is the exhaust that he is talking about. In it I listed all the bends and part numbers to make it yourself. I am also running it into a Magnaflow catback. I love this exhaust. One day I will remake it all out of stainless.
https://ls1tech.com/forums/generatio...ut-dumped.html
There is a sticky that gives you an idea of pipe diameter -vs- horsepower somewhere at the top of this board section.
Old 03-03-2015, 09:55 PM
Detoxx03's Avatar
- Install 4" Cutout
Good option
Old 03-05-2015, 07:08 PM
2001AntiVenom's Avatar
https://ls1tech.com/forums/generatio...-pictures.html
This is the basic setup you are gonna want
Quick Reply: 750 whp exhaust setup
