SLP lid and 90mm TB fitment
I'm in the process of installing my Fast 90 and all went well except now the SLP lid wont fit due to the 90mm TB sticking out a little further than the stocker apparently. Basically I can't get the lid to slide into the slots and clamp down because of all this. Anyone ever experience this? If so what did you do? Thanks
This happen to me too. I noticed the rubber coupler (smooth bellows) wasn't seated tightly against the throttle body. All I did was put some spit on the coupler and it slid right on the throttle body. Some people have to cut the coupler too because it's too long. To cut a straight edge on the coupler just leave the clamp on it to guide the razor blade.
Well I got the bellow to slide up all the way on the TB tightly so I guess I need to trim it like you're saying scotty, or go with the stock bellow. DrWhigham is the stock bellow physically shorter than the SLP one.
I'll get a pic tomorrow for you guys. I need like another inch or so to get the lid to slide into the little slots so I can lock it down. Does that make sense?
Also, do any of you know is it normal for the TB blade to be "slightly" opened when installed. After the install I noticed mine is open just a tiny bit
Thanks guys! 99Bluz28, there is only one mount position for the cable. Thats what came with the Fast. The bracket I had on my LS6 intake had 2. Maybe I could switch them. If that doesn't work then maybe I'll try modifying the mount holes like you mentioned. As far as the throttle cam...I'll have to look again since I saw only one position for the cable to go in. But the question still remains...is it normal for the blade to be cracked open slightly when the engine is off?
01ssreda4, I got the bellow to successfully fit the aTB, but I'll try that little trick if it needs to come of so I can trim it. Thanks
The Scammer Hammer
No it's not normal. There's an adjustment halfway up the throttle cable, as well as a small plastic piece that can be removed inside the cruise control module.
Post a pic of your TB. My Nick Williams has I believe 3 holes to choose from. It was minor adjustments from there. I also had my wife get in the car and put the pedal all the way down to ensure I was getting a full open blade. That's actually how I figured out I was in the wrong hole to begin with.
