What gap for 408 ???
The ngk platinum (PZTR5A-15) spark plugs are pre gapped at 1.5mm.
Would this gap be ok for a 408ci Ls1 stroker (460rwhp) ??
Moderator
Gap is about compression ratio, not displacement.
That is, really, peak cylinder pressure (CR times any
boost / jug / whatever).
If your compression ratio is similar to stock then use
a similar gap.
a similar gap.
