fast 102 intake nw tb still having issues
My throttle cables have a ton of slack in them I used the factory bracket from my ls6 intake when I made the swap has anyone had this issue before and what did u do to fix the problem? I put on the nw 102 tb and its going thru tps sensors like crazy the tps wont read zero to save its life....could both of my issues be related? I bought the lifetime warranty tps sensor from oreilleys do I need to buy a gm tps sensor?
exactly just adjust it at the tcs box takes a few seconds. As far as the tps goes, you were having the same trouble with the fast tb correct? If so I hghly recommend a gm sensor. I've been burned with crank sensors, knock sensors, and coolant sensors from the parts stores. I just order ac delco off amazon now its usually cheaper anyway lol
This thread looked helpful.
https://ls1tech.com/forums/generatio...ted-video.html
Can you get the GM TPS with lifetime?
