Where do this tool?
Where do this tool?
My brother got lucky putting his crank pulley on, but I am going to need a crank pulley installer for my cam swap. Where does everyone else get theirs from? Because no part store around me has one for a ls1. Its a 98 camaro. Thanks
i bought a longer/bigger bolt with the correct threads and several thick/wide washers from tractor supply cost bout $10. used it 4 times on 2 cars. defiantly got its use.
That's MISTER MODERATOR
Get a threaded rod, some thick washers and a nut. Grease the nut & washers. Thread the rod fully into the crank snout. Press the damper on with the nut pushing on the washers pushing on the damper. Threaded rod does NOT turn.
There's nothing wrong with heating the hub of the pulley. I've had multiple companies TELL me to do so in order to make the install easier. You can either bake it in the over for 30 min at 225 or so or just heat the HUB with a propane torch for about 5 mins. It literally falls right onto the crank, I do agree however the you should never whack it on even with a rubber mallet. If heated correctly it just slips on and bottoms out, done it many times.
I also have an install tool if for some reason I cant use heat. Either one works fine just dont use a bolt of any kind to draw it on and dont hit it with anything
Still wrong. Never use a bolt turning into the crank to pull on the damper.
Have to agree with Paul. If you can't afford the correct tool then use a stud, washers and a nut. Not a bolt. As for heating it, not only could that ruin the seal. It could ruin the balancer. They are attached with with rubber (elastomer). Heating could break the bond and the outer ring would slip.
