will jethot catted y pipe make car sound stock with cats on?
since they are hi flow, will the car sound good with the cats on? i have oo trans am with gmmg exhaust, would the sound be alot better without cats? thanks and if cats are on will the sound be ok? will you be able to tell i have longtubes?
depends on your exhaust.
if you have a loud exhaust, you will notice a difference, if you have a quiet exhaust you won't notice too much of a difference, but you will notice a difference.
personally I prefer cats, yes they rob you of some HP, but IMO the exhaust sounds soooooo much better. Even cutouts sound a lot better with cats.
LS1TECH Sponsor
you will definetly hear a difference but it will just sound alot better still tame volume wise after i took out my cats its night and day on the sound not to raspy either and would never go back to cats . by the way my setup is very close to a gmmg when compared to a few cars that had the gmmg
what exhaust are you running? i guess its all opinions on the sound, how hard is it to remove cats and make the jethot y an orp? i think before i get it all welded ill try both ways.
LS1TECH Sponsor
its a custom setup with swwet thunder mufflers similar to gmmgs setup but being custom bent it doest flow that great. sounds insane with the cut out open though one of these days ill fix it as for the cats you can alwasy try it but ill tell ya i wish i just got a ory in the first place mines all welded now anyway all the lil pieces can be a pain to line up and the race pipes fit a little tight on mine
LS1TECH Sponsor
you got it , i tossed the cats anyway wasnt even gonna bother to call jet hot within 5000 miles they were falling apart and partially clogged major increase in power above 3800rpm after i took them out , id never go back but if i was drunk and wanted to yes id have to cut it apart
Originally Posted by bluecmaro96
man for a product that costs so damn much all i hear is bad stuff about jethots catted y pipe, that sux
Also if your willing to spend a little extra cash, the muffler shop can setup the cats so they can be easily interchangeable for straight pipes. My passenger side cat is easily removable, basically 3 bolts and it slides right out, my driver side cat though is welded in place because they came with clamps and the clamps didn't work too well
the problem with having a shop around here make me a y pipe is they dont mandrel bend pipe, and i sure as hell dont want a non mandrel y pipe over a mandrel y pipe. jethot should design their sh** better .
