oil cooler lines leaking
Old 05-26-2015, 03:40 PM
dashaint's Avatar
Default oil cooler lines leaking
I replaced my radiator for the 3rd time about a year ago, to an all aluminum one.. tired of the plastic ones going out on me, and within the last couple months it has been leaking around the quick connect oil cooler lines. I replaced the oil cooler lines with new ones that go to the engine block. the connector tightens down all the way, but the lines that are held in with the retaining wire... those lines just don't tighten up. i can move them around rather easily and they are spewing oil around that area. starting to leave small puddles. i've taken them off and reconnected the connectors to make sure all was on right. is there any way i can correct this?
dashaint is offline
Old 05-27-2015, 09:42 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Is this a truck? What year?
Please tell us what vehicle you have, it's year and some details about it.
https://ls1tech.com/forums/generatio...g-threads.html
Paul Bell is offline
Old 05-29-2015, 02:17 PM
dashaint's Avatar
Smile fixed
I fixed it, i replaced the o rings on the quick connect fittings and am now good to go. fyi, there's 2 o rings per fitting one inside and one on outside. an o ring kit costs about $8.
dashaint is offline
Old 05-29-2015, 05:55 PM
Paul Bell's Avatar
dashaint, you may have noticed a lack of responses or help from our LS1tech community.
Nobody knows what vehicle you have, a year or anything. Please give us some details in the future and we'll be more than happy to help.
Did you have a read through this? https://ls1tech.com/forums/generatio...g-threads.html
Quick Reply: oil cooler lines leaking
