look please problems?? intake/injectors/ 3 Questions
3 questions
I have not had my car running right and can't get it to idle at all,, much less run smooth? ls1 ..ls6 intake 42lb injectors,,
Question 1, are the injectors seated all the way? good ones 1st then the bad ones
good,,
BAD
Question 2, does it look like the gasket is not seating? leakage at the bottom of the intake and the 2 spots where it looks like the gasket is sticking out?
Question 3, are these the low profile valley cover bolts for the ls6 intake?
Thanks everyone for looking!!
good,,
BAD
Moderator
Received 1,836 Likes
The answer to question 2 is your PCV is letting a bunch of oil into your intake. You'll need to install a catch can, since you already have the LS6 valley cover.
The answer to question 3 is no, those are not low profile bolts, but you should not need them.
I'm not sure about question 1 (they definitely don't look right), but did you tune the computer for the 42 pound injectors or just install them and start the car? If you did not tune for them, you are probably running pig rich.
I tuned them for 42,, no pvc yet, everything is just open,, I will get the catch can when I get it to where it will run.. I was still concerned about the intake gaskets, looks like they are not sealing around the bottom of the intake..Thanks for your help.
Moderator
If you rev it, does it run, but then won't idle? If so, that usually indicates a vacuum leak. If the injectors are not seated - as it appears in the pictures - you could be fighting 8 vacuum leaks
Tinker
this too...LOL
I bought them used and they were NOT supposed to be milled,, I even asked the guy that did the valve job and he said he thought they were not?? I have been reading on here about ls6 intakes and vacuum leaks,, seems they are prone to it? going to try the 2 pass torque method when it goes back on,, with new gaskets.. Thanks guys for your help!!
Moderator
OK, I have a new question for you. How long did you give it to try to learn its idle?
I just installed a set of 40-lb injectors four hours ago, and it did the exact thing you described - for 5 minutes. Now, I do know for a complete fact my injectors were seated fully.
For the first few minutes it was difficult to keep running, but if I kept my foot in it, it stayed running. Then, it started to hold idle a bit, so I took a slow trip around the block. By the end of it, it was idling great. Basically the same thing it does when installing a new cam.
SO - is it possible you just need to keep limping it along a little while longer to learn its idle?
well I took those injectors out and went with some redtop 32's and they fit better,, also put new intake gaskets in and used the proper torque method and it seems to be a lot better.. thanks for your help everyone!
