Alternator
Alternator
I want to ull it out now, but all i see is the 2 bolts in the fornt i took those off adn nothing. it doesn't coem out is there anything else holding it in?? someone told me something about some brackets in the back but i can't see ****
98 z28
98 z28
there's 4 bolts total. 3 in front, one in the back. Before you remove the bolts, disconnect the battery. DUH. Then take a small flathead screwdriver, and remove the wire plug from the top of the alternator (it's on top of the black plastic cover). Be careful you don't yank out the wire from the plug. Then unscrew the nut holding the ground lead on the back. It's under a boot. Use a 13 mm. Once that's disconnected you remove the bolt on the back on the bracket...it's another 13 mm.
The 2 bolts you probably removed are 15 mm long bolts, one up top and one at the bottom right? There's a third in the middle holding the bracket on that you have to take off. The bracket holds a small pulley too. You'll have to wiggle the alternator out of the bracket. Vois las.
