00 Z28 not starting
00 Z28 not starting
Hopefully im in the correct area, the car was being moody n would start every other time now nothing checked, relays,fuses, clutch switch it will pop start m6. Should i try jumping starter or bypass vats security light goes off n nothing when i turn the key. Thanks for any help
im no mechanic but if you've covered the basics maybe try replacing the battery cables if your sure the contacts are good & the starter is good. ps should have been posted in the maintainance thread.
