25% Under Drive & Turn One Pump???
Have a 2001 WS6. I have installed a Powerbond 25% Underdrive and absolutely love it. No problems with charge, water temp, PS, or Airconditioning. Even at stop lights everything seems in order and the car handled fine driving around parking lots. My question is has anyone added the Turn One Power Steering pump as well? This car is my daily driver, so it won't be at the track, at all, I just like the extra response and power when I want/need to use it. Will having the Turn One Pump with the underdrive make the car difficult to steer?
I run one with a 10% underdrive and its fine. The turn one still flows more fluid than what the rack needs it just flows less than what the stock one does which just flows too much. With that said i dont think itll be a problem I could barely notice it in parking lots, steering though while driving has a better feel.
Side note though I had a problem with my pump (freak thing) and learned the hard way turn one customer service is pretty terrible. Thhey make agood product though, just buy from a sponsor who will back you up
I thought about getting the 10% UD, but decided to go ahead and put in the 25% after doing a lot of research. Glad it is working for you, but the 25% UD is turning the PS pump significantly slower than the 10% one. Was hoping to hear from someone with them both in their car.
Not sure what research you did though as the 10% ati will make the same hp gains as a 25% and not take away vital dampening properties a 25% will. However that really only applies in road racing with sustained high rpm.
For the most part problem solved....
I did what I should have done and just simply called Turn One. They answered my message same day. They recommended that I buy their power steering pump with NO flow reduction since I have the 25% underdrive. That is exactly what I am going to do.
