Banging After Installing Headers
Had a few things all done at once. Speed Engineering 1 3/4" headers with the SE ORY, a Yank SS3600 stall. And poly motor and trans mounts. And a tune up with NGK platinum plugs and MSD wires. Had the computer tuned by frost. When letting off the gas I get a bad rattle underneath the car, such as the exhaust hitting the floor of the car. I know I have some exhaust leaks cause the clams that came with the headers did not seal correctly.
Today i installed my strut mount brace thinking that might tighten up the front. And maybe keep it from shaking. But if anything the banging is worse. Although the front of the car feels nice and tight.
Car runs great, besides this banging noise
Any ideas? Anybody else have these issues? If so how did you rectify the problem?
Thanks guys
PS- It gets worse when the AC compressor is on. So I am pretty sure the issue is a vibration in the motor
Thanks guys
This is where I would start also, it also would not hurt to crawl under there and double check a couple bell housing bolts, tranny mount bolt, tranny cross member bolts and torque arm bolts if wedging something in-between the exhaust and floor board does not help
i had the same issue. it was the ypipe and the clamps that camw with the kit. i got the lap joint band clamps. wrapped the joints in header wrap then clamped it down. it tightened up the exhaust alot and i have no more leaks. id go that route with the leaks issue. id bet its the ypipe banging on that part under the driver seat and or where the headers bend by the wheel well. id take a hammer to that area. had to do it on mine and my friends car
