LS61 with LS6 intake coolant issues
I've seen several of them hit the intake but it's usually on a FAST intake.
I'd be very careful,u can actually crack the intake when bolting down or it will wear a hole in it over time!!
I'd trade you a set of the stockers that block the rear off and cross over the front for yours if you're interested.
Drew408 ill keep you in mind. I don't see myself using these. I have the two sets like yours. I'm going to custom bend some lines and tap into the water pump. wanna make sure these are duds cause everyone knows nothing like factory.
