LS1 camaro with victor jr and fuel rails problem
I have a 2000 camaro with an ls1 and I bought an edelbrock victor jr intake and fuel rail kit, and a 1000 cfm 4150 throttle body. The problem Im having is the fuel rails did not come with any fittings or anything and I am unsure how to hook them up to the stock fuel lines. Any advice or information would be appreciated.
On my super victor setup I used 3) -6an to 3/8" fittings on the rails, 2) -6an 90* hose ends on the rear two fittings for the crossover, 1) 3/8" npt plug with a 1/8" npt port for a direct mount fuel gauge on the front passenger side, 1) -6an 90* fitting on the front drivers side fuel rail, and a -6an to 3/8" 45* gm style push on type fitting to connect to the stock hard line. Obviously I used -6an braided stainless hose. I would also suggest getting a 3/8" npt tap to clean up the threads on the fuel rails.
