To keep or not to keep my cats
One of my magna flow high flow cats has something loose on the inside and raddles. I can put my factory cats back on or put in straight pipes. I have a lid, potz tb, ati ud pulley, shorty headers and bassani daul exhaust. I also plan on adding a ls6 or bbk intake manifold this winter with a tune to follow. I did do lots of searching and some say do it and others say no and they feel like they lost power. Also will doing this make my exhaust a lot louder?
Moderator
Received 1,836 Likes
In general I would say you will pick up a little power. However, the cats act as a resonator of sorts. If you straight pipe them out, the exhaust can get raspy. I put a chatted Y in specifically to avoid the rasp
LS1Tech Administrator
Received 1,489 Likes
You will gain some power by removing them, but probably nothing significant. You don't ever lose power by removing them, assuming all else equal.
You will notice an increase in sound, but rasp shouldn't be a problem as you mentioned already having true duals.
Personally, I would remove them if you don't need them for emissions. The smell doesn't bother me, I'm used to it with my older cars, and the sound is much improved when you have true duals. With a Y-pipe, I might reconsider depending on muffler selection as it can get a bit raspy.
Huron speed sells xs power header systems. I purchased one with the off road x pipes. The gas smell is intense if you put your ac or heat on. I'm with the other peeps. Ditch the shorties.
