Tsp maf issues
Tsp maf issues
So I purchased a atomic airforce intake and fast 102 for my head cam ls1 and decided to go with a tsp 100 maf. My tuner has been having issues tuning the maf its getting super rich and having lean spikes at cruising speed. Has anyone else had similar issues with the ls7 style maf on an ls1 like this? The bar is set at 3 o'clock and the screen is in it, it seems like a turbulence issue at high speeds 60-80 mph on the highway when I get off throttle its rich then spikes lean when I get on the throttle. Like going down hill and then when I hit flat land and need throttle. Any fix for this? No I don't want to tune sd either I've been thinking of going back to stock maf. The car cruises just fine when the maf is off and we tuned ve. I'm at my wits end right now any help please.
nothing sounds off if you're sure the tuner knows what he's doing then you could try a 85mm truck maf since it operates and looks very much like an ls1 maf just a lot bigger. whatever you do dont go back to the stock maf, talk about a choke point....lol
you are also a brave soul for trying that msd intake....
I'll have to double check the cell ratio is next time we tune the car. we haven't been sure it was the maf until we tuned the ve and it ran like a champ then turned on the maf and stuff started getting choppy. we thought it was an issue with the bigger injectors.
LS1Tech Premium Sponsor
If you're still having problems with the MAF give us a call. We might be able to trouble shoot your problems. Like location of the MAF etc. If that's good then we can send you over a MAF start up table to help point your tuner in the right direction.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
