Crank Senor delete kit ?
Replacing my Ls1 with a Thompson MS 383, its a 5.3/4.8 iron block. I there a delete kit for where the crank sensor hole is on the left rear side of the block or should i use a sensor or a freeze plug?
CKP sensor is on right rear of block (i.e. the "other" left).
+1 confused...
PCM and/or MSD 6LS ignition controller needs to see the CKP signal.
+1 confused...
You don't delete it LOL. you need to get a new ls2 timing cover. Also the knock sensors are relocated to the side of the block instead of valley. So new valley cover as well as knock/cam sensor harness extension is needed. Places like TSP and scoggin dickey sell the conversion kits. Or just buy the parts seperatly.
