Throttle Control
Old 07-27-2015, 06:18 PM
Greg.H's Avatar
Default Throttle Control
If I were to physically open throttle with my hand on a DBW system, without moving the gas pedal, how would the engine respond? Thanks.
Old 07-29-2015, 04:53 PM
Greg.H's Avatar
Nobody knows?
Old 07-29-2015, 06:02 PM
redbird555's Avatar
Probably because no ones ever tried it. I imagine it would sound pretty horrible seeing as the pcm isn't seeing tps input from the pedal
Old 07-29-2015, 11:17 PM
Redbull87's Avatar
Only 1 way to find out,and really..its only going to do 1 of 2 things. Rev up or stall out/stumble in idle.I would assume since it has a tps at the throttle body that it will probably still rev up in rpm but also throw a code for the pedal or something.Try it and report back.
Old 07-30-2015, 07:49 PM
Greg.H's Avatar
Thanks guys. I have the throttle body for DBW and wanted to use it manually (with some mods of course) as a DBC setup. I will try and see. Or not.
Quick Reply: Throttle Control
