Better factory exhaust manifold?
I have a 96 Z28 with a rear mount turbo setup and I'm going to swap the lt1 for a 5.3, my question is are there any better factory manifolds that will fit a 4th gen? I'm keeping it rear mounted so manifolds are a must.
That's MISTER MODERATOR
These manifolds are for the CURRENT 5th gen Camaro. I doubt they'll fit on a 4th gen F-body. They are the manifolds used on the LS7 engine Z28 and can be had as a kit to upgrade your 5th gen V8 Camaro: http://paceperformance.com/i-1885589...ifold-kit.html
As the drive train for 4th gen F-body cars were pretty much identical throughout the various models, a Z28 Camaro would not get a "better" exhaust manifold than a Trans Am or SS car.
The 98~99 V8 F-body cars got stainless steel manifolds that were a bit more tubular than the later cast iron manifolds.
My Firebird catalog lists the following numbers:
98/99: L 12560194 R 12560193
00: L 12559507 R 12559506
01/02: L not listed R 12587706
Yes as a rear mount turbo, I have need to keep manifolds for the heat. Even though long tubes flow better, it will kill my spool. Z28 manifolds would rock but they are not cast and I think they will also sacrifice some spool. I have a set of truck non egr manifolds too try already, but didnt know if anyone had tried ls3 or any of the vette stuff. Obviously the high HP factory cars should have better flowing exhaust manifolds.
Will the aftermarket cast stainless manifolds fit the 4th Gen? Tru-Ram and hooker come to mind. The hooker manifolds are offered in multiple different coatings, as well.
