Cam recommendation for built 6.2L
Old 09-03-2015, 08:39 PM
Tits McGee's Avatar
Default Cam recommendation for built 6.2L
Looking for a cam recommendation for this setup:
6.0 iron block bored to 6.2L
LS2 crank/rods
Forged pistons with valve relief
PRC 225 as-cast heads with PRC dual spring .650 lift
11.4:1 CR
long tube headers
Fast 102 intake
Morel lifters
manual trans
Ford 9" 3.55 gears
26" tall tire
Car is not a daily driver but driven often in the summer. Maybe 4000 miles per year.
I checked Texas Speeds website and was considering the Tsunami or MS4 cams. Any thoughts on those or other cams?
thanks
Old 09-04-2015, 09:05 AM
DaSkinnyGuy's Avatar
I share you this info of one of the best camshaft guys to ask! Look into the cam motion brand!
http://www.guerragroup.com/#!camshaft-help/c1mq5
Old 09-04-2015, 01:24 PM
1989GTA's Avatar
Dittos on the Cam Motion brand. Give them a call.
Old 09-04-2015, 03:30 PM
HCI2000SS's Avatar
Those cams from Cam Motion sound very promising!
Old 09-04-2015, 03:37 PM
Old School Heavy
speedtigger's Avatar
LS2 crank/rods
11.4:1 CR
long tube headers
Fast 102 intake
Morel lifters
manual trans
thanks
What rear gear and tire size out back?
Old 09-04-2015, 03:42 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
I just replied to your other post as well. Feel free to give us a call. We would be happy to go over your combination and goals and point you in the right direction as far as what cam is best for you. We have several new lobe designs to quiet down the valve train and still produce amazing results while being ground on Callies cam cores. We have great new things coming out of Texas Speed! Our number is 512-863-0900.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 09-04-2015, 04:56 PM
Tits McGee's Avatar
3.55 gears and 26" tall tire
Old 09-04-2015, 06:57 PM
Pharcyde50's Avatar
I'm ready running a eps, cam motion grind. 234/242 .629/.629. Running a 4.30 gear though.
Old 09-04-2015, 07:00 PM
Old School Heavy
How do you want it to behave? Do you want a racy idle and max power, or do you want a sneakier idle and smoother drivability?
Old 09-04-2015, 08:31 PM
Tits McGee's Avatar
I don't care about a sneaky idle, but I am looking for as much power as possible while keeping the driveability good
Old 09-04-2015, 08:59 PM
Old School Heavy
You have good compression which allows for a little more camshaft, but not a lot of rear gear, so you have to take that into account. So, with that said, I would go with this cam: 237/243 111+2.5.
You can order this from Cam Motion as Grind # XA237/365-X243-355-11+2.5. It is not listed on their website yet, but if you just tell them this grind number, they will set you up. This cam will work with beehive springs that can handle .620 lift, but I would use double springs myself.
This camshaft will flat get it done with your set up. If you go to 4.10 gears later, it would be even better.
Quick Reply: Cam recommendation for built 6.2L
