Symbol performance 102mm intake an throttle body on stock ls1
Hi guys I need advice Symbol performance is claiming if I put theyer 102mm tb an 102mm intake manifold on my stock ls1 (with long tubes) I will see a hp gain from 30 to 50 horse what's your input my car is a 98 Camaro ss ls1 it's A4 an 3.73 gears an input would help because I don't have alot of knowledge with this stuff
Might wanna do some more research on that intake and company before you go wasting your money, here ya go https://ls1tech.com/forums/generatio...-manifold.html
Okay awesome info guys I did call Symbol Performance they said that their intake is different than the eBay ones the eBay are knock offs but it seems too sketchy to me especially to be paying $750 for intake and throttle body and them not help me at all I read a few good suggestions does anyone else have any other ideas on a good intake and throttle body for me keep in mind down the road I would like to do head and cam so I would like to be set up for that
There are two different companies that go by "SLP". One is a huge con and sells cheap knock offs of the real companies intake. The quality is terrible, the intake will flex under throttle, and I've even see people who have lost HP even compared to their stock intake. The injector bungs don't line up properly. The intake runners are poorly done. I suggest staying away unless you're just curious.
The REAL intake is a very quality piece and goes for upwards of $2k.
Ok awesome if I told you guys I'm just gonna keep an eye out for a used fast here on the site how would that sound or are there any other affordable intake an tb combos out theyer
Moderator
Received 1,835 Likes
I assume I'll need fuel rails anything else for this swap.. the reason I'd like to just go straight to the fast instead of a ls6 is because I'm going to do head an cam swap this way I'll be set up in the long run is that a good idea or no??
