header install help
SN95 Director
Originally Posted by Blue2002SS
undo the two bolts that you can see there and then just slide it off I think the top part slides off first. It might take a little bit of prying if its a few years old.
Use an 11mm then from the front of the car with the bolt out move the mudguard and pry the bottom, upward with a flat screwdriver. I just jerked it and off it came, then pull the shaft from the topside toward the front to remove completely.
