how to install ls6 crossover coolant lines on a ls1?
Old 09-22-2015, 10:46 PM
98camaropower's Avatar
Default how to install ls6 crossover coolant lines on a ls1?
i hae 98 Camaro I see the my coolan line runs from each side of the block in the front then goes to each side of the block in the back... im installing a fast 92 intake ws6 store gave me new coolant line do I block off the real lines an swap the front? are there any picture instructions?
Old 09-22-2015, 11:13 PM
Mappinsj's Avatar
take the long line coolant hose that connects the 4 together, off.
block off rear
add the new front cross over
one is a picture of my original 4 cross over
the other shows the front only crossover
Attached Thumbnails how to install ls6 crossover coolant lines on a ls1?-img_20150603_133753.jpg   how to install ls6 crossover coolant lines on a ls1?-img_20150528_185952_hdr.jpg
Old 09-22-2015, 11:26 PM
ok awesome that's all I needed to know but I have one more question passenger side there towards the rear of the intake theres like 3 vacuum lines wrapped together where does that go or was it a part of the egr stuff? it looks like one of the lines in that cluster comes up to the front of the intake I can see where it goes on that nipple in the front I just don't no about the back.... I also see a random small single line in the back all by itself does that connect to the 1/8 nipple in the real passengers side of map sensor?
Old 09-23-2015, 01:40 AM
possibly just vent hoses?
Old 09-23-2015, 10:41 AM
Burken01's Avatar
pcv hoses.. I would leave them alone for now
You could always get a oil catch can and delete the stock pcv lines if you wanted..
Unless they are ripped or broken just leave them..
Quick Reply: how to install ls6 crossover coolant lines on a ls1?
