Can I reuse this oil pan?
Old 10-04-2015, 12:22 AM
T/AWS6969's Avatar
Default Can I reuse this oil pan?
What u think?
Old 10-04-2015, 12:30 AM
Burken01's Avatar
Originally Posted by T/AWS6969
What u think?
If the bolt torques down properly and sits fine over the hole it should work.. Should but it's a tiny gamble
Maybe add an oversized washer for extra insurance
I'll add do at your own risk lol
Old 10-04-2015, 12:47 AM
T/AWS6969's Avatar
lol thanks bro! this was my previous engine that was boosted and broke a rod and it pounded the hell out of the inside of that ls1 block just enough to move that bolt enough to push in out and crack that small piece. i don see any visible cracks outside or inside other than that missing piece...
Old 10-04-2015, 02:34 AM
Burken01's Avatar
yeah idk
Looks pretty random, but the gasket should still seal since the inside is intact
Old 10-04-2015, 03:58 AM
subeone's Avatar
yes it will seal... done it at least 10 times already
Old 10-04-2015, 09:38 AM
BOLO's Avatar
If its for a new built engine, and you're already spending money, then spend money and get a new pan. Otherwise, if its just to get by, it's should be ok, as mentioned.
Old 10-04-2015, 11:11 AM
That's MISTER MODERATOR
Paul Bell's Avatar
I'd buy a new pan. One less little thing on your mind after assembly. Comes with windage tray, oil pump pickup tube, level sensor, gasket and bolts. It uses a different oil filter though.
Quick Reply: Can I reuse this oil pan?
