Best LT/X-Pipe Setup for C5
Old 10-13-2015, 09:49 AM
lsfanatic's Avatar
Default Best LT/X-Pipe Setup for C5
I want to put long tube headers and a catless x-pipe on my C5 this winter. I had been looking at the kooks 1-7/8" race header with the catless 3"x3" x-pipe they have. Seems to be a good blend of performance, quality, and price.
However Texas speed has a 1-3/4" setup for the C5 that comes with an x-pipe and is considerably cheaper. How much is the 1-3/4" primary going to restrict things? I plan on doing heads/cam within the next year and I don't want the headers as a choking point.
As for the kooks setup, it looks like their primary O2 bung is located at the collector but only in the flow of one primary. Has anyone run into issues with it not reading from all cylinders?
Kooks also makes a 2" primary setup, which seems like it would hurt the low and mid range power, but how much? I am considering eventually supercharging the car and going close to 1000 hp, but would 1-7/8" suffice in that application also?
Thanks for any input. I feel like the more I research about it, the more confused I get.
Old 10-13-2015, 10:04 AM
scotty2000ss's Avatar
Based on your goals I wouldn't consider 1 3/4". Have you considered ARH? If it were me I would look into these
http://www.customcorvetteaccessories...iyheaders.html
Old 10-13-2015, 10:11 AM
lsfanatic's Avatar
That's the thing, if I got 1-3/4" now I would have to buy different headers eventually. Which in my mind negates any cost savings seen by buying cheaper headers now.
I have seen those. I like them, but holy $$$.
Old 10-13-2015, 10:12 AM
How much is the total cost for the Kooks set up?
Old 10-13-2015, 10:25 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I personally have the Kooks 1-7/8" race header with the catless 3"x3" x-pipe on my 03 C5 Z06 and they had great fitment and made very good power. I have never had any kind of issues with 02s on my car and haven't really seen it be an issue. Unless you are building some crazy setup I would stick withe 1 3/4 or 1 7/8 primary headers. I would personally go with the 1 7/8 as it will give you room to grow and won't really effect the bottom end torque.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-13-2015, 04:05 PM
lsfanatic's Avatar
About 1300-1400 from MD Speed.
Thanks for the input. Does the 3"x3" x-pipe have a 3" flange at the end or does it end in a 3" pipe?
Old 10-13-2015, 06:48 PM
MonmouthCtyLS7's Avatar
Monza EBay setup ftw, 1 7/8th Headers and ORX at a 1/4 of the price.
Old 10-13-2015, 10:27 PM
lsfanatic's Avatar
Is the ID of the pipe true 1-7/8"? And do they fit on the car without hammering it into submission?
Old 10-14-2015, 06:15 AM
Yes they're 1 7/8ths. I had a local experienced C5 guy do the install and he was surprised on how good the fitment was. He said the install went very smooth.
Old 10-14-2015, 06:37 AM
Any numbers after the install? Do they have a merge collector?
Old 10-14-2015, 06:56 AM
Yes its a merge collector, no numbers the car was street tuned.
Old 10-14-2015, 09:06 AM
Toddoky's Avatar
Tubing size specifications are related to the O.D., not the I.D. like pipe is, which means the actual I.D. of a tube is dependent on the wall thickness of the material...thinner gauge tubing has a larger I.D. than thicker gauge tubing does.
Old 10-14-2015, 09:39 AM
BMR Sales2's Avatar
My X-pipe has the flanges on the back side of it.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 10-14-2015, 11:27 PM
lsfanatic's Avatar
Interesting...
Not really sure what I was thinking when posting that, of course!
Okay, thanks.
Any one have any info has to whether the Pfadt/AFE headers really make more power (peak or under the curve) then a traditional 4 into 1 header? In theory they should, but its pretty expensive premium if there isn't much advantage.
Old 10-15-2015, 03:44 AM
Take a look at this.
https://ls1tech.com/forums/generatio...eaders-10.html
Old 10-15-2015, 09:55 AM
lsfanatic's Avatar
Hmm...read the whole thread, sounds promising. 352/368 rear wheel hp/tq seems really good for headers and a CAI. Curious what it does with heads/cam. The question though is whether or not the extra cost is worth the extra power.
Old 10-15-2015, 10:20 AM
To me, it's totally worth it in the end. All the "little" things matter when making a combo work. If you paired HCI with those headers the results are going to blow away anything else based on how they work. Just my .02
Old 10-15-2015, 11:34 AM
farmington's Avatar
don't go only by dyno numbers. some "happy" dynos give very high readings.
Old 10-15-2015, 11:50 AM
That's why I personally couldn't justify spending $1500 for a Header/Xpipe setup. Mine cost around $500 all together. It added some good power, along with being 1 7/8 & stainless steel. Some things you cant go cheaper on but imo exhaust is one that you can. Big difference in Ebay exhaust systems 10 years ago .and today.
Old 10-15-2015, 03:51 PM
Look at the torque curve in that thread that I linked. No cheap Ebay header is going to give you results like that. You get what you pay for. The op mentioned some big plans. Exhaust will play a huge role no matter what the combo is.
Quick Reply: Best LT/X-Pipe Setup for C5
