LQ4 intake manifold bolt questions
Old 10-15-2015, 02:30 PM
Sam Loffler's Avatar
Default LQ4 intake manifold bolt questions
First post here. You guys have been a ton of help with my 6.0 rebuild.
Anyway, its all together, installed, and running pretty well. However, I have a vacuum leak around my intake manifold and I can't get the front bolt on the pass side to torque down. I ended up stripping the top 1/4 in of threads in the hole in the head. Im thinking I should be able to get a bolt that's a half inch longer and take care of it.
So my questions are:
1, are the sleeves and plastic washers required on the bolts?
2, what size are the stock bolts? 6x1.0, but how long?
Old 10-15-2015, 10:12 PM
LS1MCSS's Avatar
The stock bolts screw in a lot more than 1/4". If that's all your were in, then you have other problems somewhere.
Quick Reply: LQ4 intake manifold bolt questions
