Name this flywheel-and how do i get it off-
Old 11-29-2015, 12:26 AM
Txsilverc6's Avatar
Default Name this flywheel-and how do i get it off-
Cant get a puller on it cause of the odd thread/ bolt size. Tried all pitches of m8.. tried M7 1.00 fits but too loose. Thought i read somewhere this was M7 1.25... thats a hard bolt to locate ?>?> google search didnt turn up much. any ideas or strategies?
Attached Thumbnails Name this flywheel-and how do i get it off--flywheel1.jpeg   Name this flywheel-and how do i get it off--flywheel-2.jpeg
Txsilverc6's Avatar
Its on my c5 ls1.
Old 11-29-2015, 02:02 AM
Jontall's Avatar
You have got to be kidding with those pictures... My microscopic is out for service right now, so I really can't see whats going on. 2004 Corvette LS1 flywheel bolts are: M11X1.5X23.5 W/SEALER, GM part # 12553332. Pressure plate bolts are GM part # 12561465, and they are M10X1.5X25 10.9.
Old 11-29-2015, 07:57 AM
KCS
Moderator
KCS's Avatar
Looks more like the damper on the front of the engine...
Old 11-29-2015, 07:59 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Txsilverc6, that sure doesn't look like a flywheel to me.
More like a harmonic balancer, like aftermarket.
Is this item on the front of your engine?
Old 11-29-2015, 11:08 AM
Txsilverc6's Avatar
Default Its a harmonic balancer
See what happens when frustration sets in.I meant HARMONIC BALANCER. I cant get the three little hole matched with proper sized bolts - no bolts no puller- no camshaft removal- Just when i thought i could see the end -three odd sized bolt holes stop everything. Any ideas?
Its a harmonic balancer not a flywheel - damn car is winning
Old 11-29-2015, 11:59 AM
Paul Bell's Avatar
It looks that a pully registered on the face retained with three bolts. Do you have them?
Have you tried some SAE (non-metric) bolts?
Old 11-29-2015, 01:09 PM
Txsilverc6's Avatar
Paul Bell: Thanks for the face comment..went outside and wiped down the balancer real good and POOF!! WORDS stamped on outside ring. Added a little powder to enhance the stamp..and here it is.
Old 11-29-2015, 01:35 PM
Paul Bell's Avatar
Here's the closest I can get to your part number. No mention of fastener thread sizing though.
http://www.autospecialties.com/gm.html
Old 11-29-2015, 03:07 PM
Jontall's Avatar
At least now you can call them Monday morning.
Old 11-29-2015, 03:11 PM
usdmholden's Avatar
Are you positive it's not a standard thread?
5/16 is smaller than 8mm and 24 TPI nearly lines up with 1mm pitch.
5/16-24 is UNC fine.
Old 12-02-2015, 09:27 AM
Txsilverc6's Avatar
5/16 fits perfect. Pic updates coming. Thanks all.
Old 12-02-2015, 10:10 AM
usdmholden's Avatar
For the life of me I have never understood why aftermarket companies take an entirely metric engine or car and design in non metric fasteners. Aftermarket has been doing this for as long as I can remember.
Unless someone re-drilled and re-tapped.
Glad you got it figured out.
Old 12-02-2015, 04:47 PM
Paul Bell's Avatar
I think they do that to keep it standard. Balancers have always had SAE fastener sizes. Also, us old guys with our old tools have pullers without them newfangled foreign metric bolts in them.
Don't matter, metric ain't never gonna work here!!!
Quick Reply: Name this flywheel-and how do i get it off-
