Is Hypertech 180 degree thermostat worth the cash?
Old 11-30-2015, 01:38 PM
Fullblast's Avatar
Default Is Hypertech 180 degree thermostat worth the cash?
I ordered a 180 thermostat the other day and they QUOTED me $13. When it got here it was a hypertech 180 for $60. They said that's the only lower than 187 degree thermostat they sell, except for the 160 degree for $30.
I don't really want to pay $60 for the thermostat unless it's worth it. Are there any cooling/hp gains to be had from switching from 187 to 180?
I live in Texas where it gets brutally hot. I thought about the 160 but I have heard a few people have problems with them. Any thoughts?
Either way, I am getting a tune, so now is the time to replace the thermostat if it's even worth fooling with.
I have asked a similar question before, but I couldn't find the thread. Thanks
Old 11-30-2015, 03:12 PM
Russ K's Avatar
The 180* stat runs at the same temp as as stock stat. I use the 160*, and my coolant temps are 172*-174* at highway speeds. Yes the early LS stats come with the water neck, that's why they are more money.
No issues with a 160* stat in warm climates.
Russ Kemp
Old 11-30-2015, 03:17 PM
HCI2000SS's Avatar
I really recommend going with the 160 and having the fans reprogrammed
Old 12-01-2015, 01:58 AM
Black02SLP's Avatar
Fullblast. Off the subject but what horse power you putting out? I was looking at your specs and it is the same combo I was thinking of going with. The exact same actually.
Old 12-01-2015, 04:11 AM
joecar's Avatar
Summit racing has LS1/LS6 style thermostats (includes the inlet housing) in 180* and 160* for about $30 or so.
Old 12-01-2015, 07:16 AM
Fullblast's Avatar
The motor is being rebuilt right now. It should be finished this week and then we're gonna dyno tune it. I'll post the numbers then.
Old 12-01-2015, 07:36 AM
vettenuts's Avatar
You can modify your own for $1 and about 10 minutes worth of work.
Old 12-01-2015, 08:58 AM
high n dry's Avatar
How so???
Old 12-01-2015, 10:46 AM
joecar's Avatar
( put the right sized shim under the thermostat's spindle in the inlet housing )
Old 12-01-2015, 01:49 PM
redtan's Avatar
I got my 180* for 25 bux.
Old 12-01-2015, 02:19 PM
gtfoxy's Avatar
Then test opening temp & operation in a pot of water brought to a slow boil with a Thermometer.
Old 12-02-2015, 07:08 AM
vettenuts's Avatar
I wrote this for the Corvetteforum several years ago. I have updated it here with the final shim I am now using.
There have been two threads recently on modifying the stock thermostat (a modification that isn’t discussed much anymore) and I recently got to check the new thermostat I just bought out of the box and then with a few different thickness shims. My goal is not to get a real cold thermostat, but rather get one to open around 180 degrees with good flow by the time the thermostat is in the low to mid-190’s. I am hoping that with the DeWitts radiator I have on order and this slight modification to the thermostat, I will be able to keep the engine temperature in a narrow range from 185 – 195 degrees from spring right through fall while ensuring my oil temps are over 200. That’s the goal; guess we’ll see how things work out in the coming months and if the oil doesn’t heat up enough I will re-install the stock unit. The other thing worth noting, the temperatures I am trying to achieve are based on how I typically drive the car as I don’t race the car so extended high RPM runs are simply not in the cards.
In the first photo the thermostat has been disassembled. You can see one of the shims that I made and the hole into which it is installed. The thickness of the shim will alter the opening point by lowering it, or as is the case if you get to approximately 0.100” thick shim, the thermostat will barely close.
One of the problems I ran into was how to measure data so it wasn’t subjective and I could repeat the test fairly well between the different shims and get a good comparison. After some messing around with the test, I decided to take the temperature at three points in the opening sequence. First, by hanging the thermostat such that the neck was downward, it was easy to trap air behind the rubber door that opens in the thermostat. The first data point would then be when the thermostat opened enough to release the trapped air. This doesn’t take much movement at all and you can barely see the rubber door move at all when this occurs since the movement is so slight. The second point of measurement would be when the rubber lip on the seal was even with the flat mounting surface of the thermostat (see the photo). Finally, I took a third measurement when the rubber lip was 0.2” from the same flat mounting surface. While this seems to be a precise number, it is actually the width of my flat screwdriver that I could hold in the water and use for a measuring tool. With one edge of the screwdriver against the flat mounting surface of the thermostat, when the lip was even with the other edge of the screwdriver blade that is when I wrote down the temperature.
Below is a photo of the shim installed prior to re-assembly of the thermostat.
Next was the method of heating up the thermostat so it was immersed in water. In the next photo you can see I bent up a coat hanger and hung it from a small stick across a large pot of water (my wife thinks I should be committed at this point ). The wire next to the thermostat is the thermocouple that was tied into a Fluke Meter for measuring the temperature.
Below is the Fluke Meter that was used to monitor the temperature, which is accurate to 1/10th of a degree.
Here is the data that I obtained, noting each shim was tested several times to obtain these average values:
It appears that with the 0.098” shim, the thermostat is barely closed. The 0.058” shim didn’t quite get me to where I wanted to be. The performance of the 0.075” shim, which seems to seal the thermostat better when it closes down again, will hopefully provide me the temperatures I am trying to achieve in the motor. However, if it is too cool the data will be used to make adjustments as necessary to get to my final goals.
I ran the 0.075" shim for a while but in the motor it was too cold. Further experimentation in the motor brought me to a final value of 0.045" shim. My motor runs between 180-185 while cruising (depends on outside temperature and what the motor is doing, i.e., higher RPM cruise vs. loafing on the highway). Oil is typically 198 or higher depending on outside temperature while driving. In the summer it will get to 208.
Old 12-04-2015, 03:32 PM
Pharcyde50's Avatar
I'm running the 160. But its pretty much worthless unless you adjust the tune.
Old 12-04-2015, 05:19 PM
MonmouthCtyLS7's Avatar
Installed they're 160 w/ a tune over the summer and the car definitely ran cooler. Been driving her here and there year round and the car seems to warm up just fine in the cold weather.
Old 12-04-2015, 06:15 PM
01WS6/tamu's Avatar
Nope complete waste of cash. LS engines are designed to run the stock 195 and make most power and fuel mileage. Old school SBC techniques of cold thermostats and does not apply to modern LS engines. They are designed to run hot 210 220 is not "hot" and that's their happy zone.
Old 12-04-2015, 08:20 PM
kinglt-1's Avatar
^This
Old 12-05-2015, 02:40 PM
2xLS1's Avatar
Hot for emissions, not performance.
Old 12-05-2015, 02:52 PM
joecar's Avatar
+1 emissions and performance counter each other.
You will find that cooler ECT will allow you to run a few more degrees of timing (without pinging) which gives you a little more torque.
Old 12-05-2015, 03:35 PM
HCI2000SS's Avatar
Yep and this is exactly what happened in my case
Old 12-05-2015, 04:32 PM
Fullblast's Avatar
I went ahead and got the 160 degree thermostat for $30. I have an off road y pipe and a cam, so emissions are the least of my concern.
Timing advancement was the biggest point for me. Getting a little more power and torque with a cooler running engine sounds great.
Also, Houston is one of the hottest places in the Us in the summertime. 100 degrees plus humidity in back to back traffic is very hard on the engine. I would say that only New Orleans heat and humidity rivals Houston. It's like your inhaling soup for air. I've been to Arizona and the desert states and the drier heat does not compare.
Quick Reply: Is Hypertech 180 degree thermostat worth the cash?
