WHERE TO .. Relocate Your IAT
Old 01-01-2016, 11:36 AM
Stealth Camaro's Avatar
Default WHERE TO .. Relocate Your IAT
Come on guys.
I have searched the forum and read a lot of threads but with no direct info/pictures.
Do you guys just get the extension and have it somewhere under the hood ? under the windshield ? behind the front headlight ??? or just tight it to lower part of the SLP/chrs1313 ram air ?
Old 01-02-2016, 11:57 AM
Firebirdmuscle's Avatar
I drilled a hole towards the bottom of th chris1313 and bought the extension harness and put it down there. Not sure if there or up in the silicone adapter to the tb would have been better. It works just fine down there though.
Old 01-04-2016, 12:20 PM
Moderator
jimmyblue's Avatar
Mine sits up under the cowl vent plastic, a short bit
of wire to get it there from the PCM connector. It is
a pretty good spot.
Quick Reply: WHERE TO .. Relocate Your IAT
