HELP: Speed Engineering 1 7/8 LT to Magnaflow.
Over the weekend my buddy and I replaced my Hooker LT 1 3/4 headers and y-pipe and installed Speed Engineering 1 /7/8 LT headers and off road y-pipe (Part #: 25-1020+25-1002). The headers and y-pipe went in smoothly with no issues but when I tried to connect the y-pipe to my Magnaflow exhaust, (Part #: 15684), the tubing was to long. Looking at it from under neath my T/A, the tubing connect to the y-pipe would push past the connection that goes over my rear-end.
It looks like I need to cut off about 2" inches off the tubing but I was wondering if anyone else had similar issue(s) or may have another solution on this setup. Thanks for any advice/help.
i have this exact same set up. i had my cat back installed (too burnt out after headers) so that way it can get all lined up nice. my mechanic did not mention anything about it being too long... im assuming you double checked to make sure everything is slipped on at the max?
Did you have any issue(s) at all with the install?
