fuel injectors
Old 02-02-2016, 06:45 PM
lsxchevelle67's Avatar
Default fuel injectors
i am building a 2006 lq4 with a gm hot cam 219/228@.050 .525.525 lift
what are the best injectors to run
Old 02-03-2016, 05:30 AM
MonmouthCtyLS7's Avatar
Bosch 36#ers should be fine, they can be found pretty cheap.
Old 02-04-2016, 03:43 PM
bclounch's Avatar
I have an LQ4 with similar cam specs 216/224 .551 and run Fast 36#. They are at around 65% WOT.
Old 02-04-2016, 03:53 PM
Default How much power you see out of your set up
how much power are you seeing for your set up
Old 02-10-2016, 09:44 AM
farmington's Avatar
the factory ones should work for you. your tuner will tell you if you need bigger injectors.
Quick Reply: fuel injectors
