DBW Throttle acting funky
Old 03-04-2016, 03:38 PM
NathanH1997's Avatar
Default DBW Throttle acting funky
Finally got my trans problem fixed. was simple as one of the wires not being seated in the PCM connector.
Now I've got a throttle body problem. it is odd. I can turn the key to the on position. press the throttle, and you can hear it open and close. I start it, and it'll start fine. Then I can press the throttle for a few seconds and it will rev. then the pedal goes dead. no throttle response at all. it just idles. no more, no less. just idles.
2003 5.3 and 4l60e LS Swapped into an '86 C20 pickup.
Old 03-04-2016, 09:45 PM
mikesimpalass's Avatar
Any trouble codes? Sometimes if you have a bad ground they will act like this.......I know this from experience
Old 03-05-2016, 08:13 AM
garys 68's Avatar
Sounds like it's going into limp. It should give you a code. Did it run well before, or is this initial startup for your swap?
Old 03-05-2016, 09:18 PM
Ran a bunch of different ways
Ran poor, with all four gears in the 60e trans.
ran good, with 2 gears in the trans cause of a bad 2-3 shift wire and a replaced exhast gasket
now it doesn't go off idle without dying. it'll putt around at idle, and if you go SLOWLY onto the gas, and I mean SLOWLY, it'll get up to speed. but it has all 4 gears!
Could this be a battery problem? The truck had sat before this for a while, and something drained it pretty dang good. took several minutes for me to be able to start it with jumper cables on it.
Old 03-06-2016, 06:43 AM
garys 68's Avatar
Any codes, check engine light?
If you gas it hard and then will only idle, it's probably in limp mode. That usually requires a battery disconnect to get back any throttle response. The code will help tell if it's the TAC, pedal, or wiring.
Quick Reply: DBW Throttle acting funky
