Early Stock Corvette VS F-Body Fuel Rails
I have searched but needed a simple explanation.
I see that early Corvette fuel rails have the return line and the 98-02 F-Body rails do not have the return line. Other than the 98-02 F-body rails fitting on the early corvette, are there any other stock fuel rails that fit the early Corvette manifold without modification? Thanks
LS2 and LS3 rails are the same, and they will not bolt on. They can be made to fit, but the rails will need to be modified and spaced up to fit. It isn't difficult, but it isn't a direct swap.
This is one thing I had to do to get an LS2 fuel rail on an LS6 intake with LS1 injectors:
