Coolant sensor help
Coolant sensor help
Hi I'm swapping a a 5.3. I put ls6 top end on it with heads and intake. I ran I to a little issue I would like to ask a question about. Bough the heads used. Seems like one of the threads was tapped to 1/2 npt (just guessing but looks that size). I didn't notice this when installing that head is on drivers side. So the coolant sensor for ecu is to small does not thread in tight. I can move it to the pass. Side head. Would this cause any problems of any kind having the sensor in the back of the passenger side head?
I read a couple threads last night where people switch sensor to back passenger head for ease of rework and cleaner harness ect.. so I think ima try it out if it is causing an issue then I would hope there some kind of adapter that I can use to put it in the driver head that has been tapped. I would really hate to have to switch heads around.
The rear of the head is always going to be cooler than the front. If the ECU reads that as a operating temp, it will think it still needs to be in cold enrichment mode.
You could reprogram the ECU to identify this cooler temp as standard operating, that's not a big deal at all.
But you'll want your gauge port to be at the front of the engine, so you can monitor the hottest temps.
