Catch can routing for MY particular car please look and advise
I have the drivers valve cover completely blocked off.
The passenger side is routed:
Dirty going into the catch can.
Clean to the intake from the catch can.
Then front throttle body to the passenger valve cover.
My question is should I remove the breather from the valve cover for better suction? Also would this be considered a functional install?
Ls2 engine
Thanks atrus
I don't know what to hook that side up to on the drivers side. dumThere was a nipple there I capped it off. dumMy passenger cover has only 1 nipple going to the catch can. I have seen covers with 2 but mine only has 1.
I assumed having the breather would simulate sucking a straw with a hole in the side. I wasn't sure because I see this setup with different configurations.
You can run breathers and a pcv system but you have to cap off the fresh air inlet. Then the breathers become the fresh air source. Otherwise it's just a vacuum leak.
Fyi fresh air hose is the one from the tb to vc.
Closed vs open setup
I have seen diagram after diagram and you are right.
I would get more suction from no breather there. Which is safer on a H/C Nitrous car I mean simply which is better for the engine?
Also am I ok by completely blocking off the drivers valley cover?
If its better to loose the breather I dont mind I can put a regular cap there. If it is better to cap the fresh air inlet I can do that too.
Thanks
Thanks
Honestly with all the money you've spent on the engine buy yourself a good catch can while you are at it. Mighty mouse, RX, or Elite.
Thanks for answering JD!!!
I got the idea of the breather there from mighty mouses diagram. I couldn't get the final answer to my question here. On his diagram the only difference was a T from the drivers valve cover to the passenger that's why I asked.
I read several places that motors with over 700 HP need a breather too so just in case mine would be over 700 HP I added one to the can. I can say it does catch some oil not much but enough to haze coat the inside of the intake. I am going to clean the inside of the intake one more time and see what happens.
That can I took apart and added baffles and locked the steel wool down to the bottom to catch the oil, I also have a tube going down into the center of the steel wool with holes drilled down each side.
The Can was 18.00 shipped, the steel wool was 1.50, the breather was 1.98 shipped the barb was 2.25 the mesh I used for holding down the steel wool was free I had it already. I just ordered a 12mm check valve for 3.50 shipped, I will replace the barb with this...I actually ordered two for that price just in case I need one somewhere else. Thanks for the knowledge and to all who answered thanks for taking the time to answer. After the check valve...I promise I will leave the breathers alone .
