2002 trans am just shuts off
Old 03-31-2016, 04:16 PM
LS White Dragon's Avatar
Default 2002 trans am just shuts off
My car tends to turn off without a warning and it's become common. I have replaced the alternator and battery and it still dis out on me. I checked to see if my fuel pump is holding pressure it it seems fine. Also inspected the fuel pump fuse and it was normal....my car isn't throwing a check engine light and I'm stumped...help?
Old 03-31-2016, 07:09 PM
ggino85's Avatar
Something similar happened to me awhile back and it ended up being the started solenoid or the ignition solenoid. Try swapping around solenoids to see if that stops/cures it. Only do two at a time so you can make sure you don't forget where they originally came from.
Old 06-19-2016, 02:36 AM
Really appreciate the advice, but after a long process of elimination I solved my problem. I had a loose crank sensor connector. The wires were badly damaged soI bought a new connector and soldered it on...it has run smooth ever since. Hopefully this can help somebody in the future.
Quick Reply: 2002 trans am just shuts off
