Alternator dropping voltage at high RPM?
Using a 98 LS1 alternator thats about 2 years old now. Factory diameter pulleys.
Recently looking at my logs it looks like my voltage drops from a steady 13.9 to 12.5 or less above 5800 rpm? This a sign of a alternator that is about to go? Or possible belt slip? This common at all?
I've had alternators just quit, but never seen one drop voltage at RPM and then pick right back up again at idle and lower RPM?
2 things that could cause this and i experienced both.The belt would slip at high rpm and not spin the alt enough,this was a combo of a weak tensioner for me and a old worn out belt.And 2nd is the alt itself was failing on the regulator as mentioned above. Check the easy things first and then have the alt checked.I upgraded to a truck alt at the sametime for the fact of the higher amperage needs on my car.
