replacing motor in 2001 pontiac trans am
I replaced the motor and put new texas speed headers in. I want to know where the the vacuum lines and back of the intake right where the brake booster plugs into. What are those vacuum lines purpose? I have them highlighted in the photo below.
please respond asap, i'm putting the motor in right now and i need to know.
That is correct. I just had this issue when I switched to a FAST intake and forgot to hook it back up. You wont be able to control your vents without it as they are vacuum controlled. The hose to connect to it is in the wire loom along the passenger side of the firewall.
