Holley Hi-ram for appearance only? What injectors?
I've read tons of threads on this intake. Here are my questions...
This is on a stock 5.3 in my Street Rod 1936 Chevy.
Will this make the car a complete dog or will the losses be marginal?
What will I have to change injector-wise? (stock truck injectors now).
Will my stock DBW throttle body work?
Thanks,
Richard
Thanks,
Richard
Moderator
Isn't there a "Mid-Rise" Holley manifold available? It might save you some of that low end power and still have the Hi-Ram look.
BTW, you can look up the instruction sheet on Holley's website and it will tell you what injectors to use. Should have info on the TB bolt pattern too, but I'm 99% sure a stock DBW TB will boot right up, depending on the top used of course.
