Port Matching... What it's worth?
I want to know how critical is port matching the heads to the intake...
Let's say I have a 408ci motor with out the box aftermarket heads and a out the box fast intake and the car run 10.9s at the track..
How much of a E.T drop or mph gain will I see at the track if I sent the heads and intake off to a good porter to get them port matched to each other?
Fast 102mm intake Orange Juice.
KCS I KINDA agree with you but rectangle port don't really start to shine to 5500 rpm or so..... even on a big cube motor the cathedrals hold they ground well. The fastest all motor pump gas LSX setup uses TFS 235 heads on a 445 ci motor by HKE with a fast intake.....
402ci,11.6:1 compression,24x/25x cam,out of the box tfs 235's,out of the box fast 102mm.
Car runs ..... 10.6 at 130 mph with 1.5X 60ft.
Now how much faster will I be at the track if the heads/intake was optimized to each other ?
I took a pick/scribe tool and heated it up to bend into a "U". Held the base down on the head and using the U reached inside the intake and used the head as a guide to scribe the face of the intake. Used a cutting tool on a drill to open them up to the lines. Feathered out the rest of the intake with a sanding roll.
Anyone ever try and use a fill compound. If there was something safe to use I would have built up to match the top of the cathedral section of the head.
Hmmmm interesting
After all the time spent on the intake can you tell a "seat of the pants" difference ?
