oil pressure and water temp gauges
Where do you install the water temp and oil pressure gauge at?
I was thinking about installing the water temp gauge on the pass side head where the plug is at?
And the oil pressure gauge would go into a tee where the sender is at?
What do you all think?
Thanks
Thanks
Of you are referring to the place above the starter for the water temp thats what I did and it worked fine. And I did my oil pressure right where you are referring to worked great.
1 Post
I used the hole above the starter..
For the oil temp guage I had a buddy tap into the piece right above the oil filter. I don't remember the site that gave me the idea to tap in there. I'll look.
