Aluminum or light weight coil pack trays
I found a kit on eBay that I might get and use it as a base and modify it.
https://www.ebay.com/itm/331633066590
Hopefully that might help you.
I enjoy building stuff like this for my cars.
Pretty expensive brackets. the plug wires are $93 at Summit Racing. You have to supply the coils, and modify the wiring harness. The brackets are about $15-20 in material, and probably no more than 1-2 hours to build if you're slow and use hand tools.
https://ls1tech.com/forums/appearanc...ics-added.html
As I am wanting to put them down on the motor mounts to. Just have to see what my options are when the time comes around this winter.
Last edited by Firebirdmuscle; 10-30-2016 at 10:17 AM. Reason: Realized I had the wrong link
Carbon Valve Covers
I would like to know of your choice of the Valve Cover manufacturer ?
I would like to speak to him, to "add" the mounts directly into the Valve Cover for my IGN-1A coil kit.
I have done this for my ALUMINUM 6.1 Hemi valve covers.
Lance
Lance
