Crush bent horsepower loss
I bet you aren't losing anything. A properly tuned exhaust will get smaller as it gets longer so the slight bends at the back are more than likely fine. I would go with cutouts behind the headers (like someone else mentioned) if you are worried about a couple of HP.
Did you watch the video I posted on the first page of this thread? I would have thought they would have lost power right away and after everything they did to those headers and it made very little difference. I just installed 3" mandrel exhaust on my truck with cutouts but it's supercharged so the exhaust side needs all the help it can get.
FWIW, I have a puny jeep Wrangerl 4cyl, I had the motor warmed up and upgraded to a metal cat and a spintec with 2.5 instead of the stock 2.25 pipe, The exhaust change didn't register much on the butt dyno, but the engine reved much better above 3500 and my mileage went up a consistent 2-3 MPG on the highway.. YMMV!
#33
How true , your the first to say that in all the exhaust threads I've ever read ! I have been preaching that for years but most guys just don't get it. That is one of my biggest priorities I have in designing a exhaust system. I try to within the constraints of the app to reduce the amount of degree and number of bends. But most guys get caught up in the mandrel , or size , bling or sound as deciding factors.
#34
My exhaust is setup like this. 1 7/8 headers to 3" collectors to straight thru flowmasters, Right after that are the cutouts that dump before rearend (no room for crossover) Then over the axle to another larger set of straight thru mufflers and very short tail pipes. I haven't ran it yet so I'm not sure how it will sound. I didn't want cutouts right after the headers because I think open headers sound terrible so I put on the mufflers to tone it down a little and then the second set of mufflers to tone it down even further after the cutouts.
I'm running a 6.0 with LSA supercharger/TR6060 in an S10 I'm hoping to be able to quite it down enough to be able to cruise down the highway and not have the noise drive you crazy.
Here is a mock up shot of my exhaust still have some work to do yet.
#36
Still have body work/paint to do.
#38
