FAST 90 Porting??
Old 01-04-2017, 12:38 PM
Rise of the Phoenix's Avatar
We'll see how the red turns out. I'll get some pictures up this week.
Old 01-10-2017, 01:28 PM
I just realized something. I think the primer I purchased goes on black. Is that going to be a problem then trying to paint the intake red?
Old 01-10-2017, 01:43 PM
thunderstruck507's Avatar
It shouldn't, might take more coverage to get the red color though. I would try to exchange the primer for some gray instead.
I would say just try it but if the red doesn't cover the black primer well it can be a pain to correct because you would need to strip it and get back to bare.
Old 01-10-2017, 02:18 PM
Is the primer really needed? I thought I read on here where a guy just used paint to paint the intake and it turned out great.
Old 01-10-2017, 04:10 PM
Jtm2085's Avatar
I painted mind with krylon fusion black and clear. No primer
Old 01-10-2017, 04:23 PM
I painted mine without primer.
Works fine, but the finish isn't very resistant to scratches. Not sure if primer would help much or not.
Pretty sure I mentioned before I just used straight Krylon after cleaning the intake, but a lot of people do prefer to use the primer and adhesion promoters so I just wasn't trying to tell you what you were doing was wrong.
It has been my experience that trying to put spray primer over spray paint 100% does not work...there is a strange reaction that looks like cracked lava as the primer dries. So I always make sure to do whatever primer I intend to to well and if I'm not happy with the texture fix it BEFORE doing any painting...it's a real mess trying to strip paint and primer to get back to ground zero to start over.
Old 01-10-2017, 04:40 PM
ragtopz28's Avatar
Originally Posted by wph351
satin black is the only way to go. Painted my fast 90 monday. It has a bedliner-ish look to it. Just a bit smoother. Looks awesome.
You got a pic for us?
Old 01-10-2017, 05:25 PM
RollinSScamaro's Avatar
I didn't prime mine.. high temp 500 degree duplicolor paint.. turned out perfect with a lot of light coats.. cleaned the intake with grease and wax remover that my friend had from autobody work
Old 01-10-2017, 06:53 PM
First coat of paint on and so far so good.
Old 01-11-2017, 10:20 AM
Painting has been completed. I applied three coats of the red over the intake and opted not to use primer. The coverage was great and the red really stands out and looks nice. I decided to let the intake fully dry overnight/throughout today, so I'm going to apply the clear-coat tonight. I'll get some pics up tonight.
Old 01-12-2017, 08:30 AM
Here is a picture of the finished product. About 3 coats of the red paint and then 3 coats of clear. I still need to purchase a paint pen to outline the FAST lettering in black.
Old 01-12-2017, 10:55 AM
  #32
ragtopz28's Avatar
Did you do the valve covers too? Post up an engine bay pic when all done
Old 01-12-2017, 12:40 PM
  #33
I'll be painting the valve covers black and the coil covers red. I'm still deciding between the red or black powdercoated TB from WARR Performance. Not sure which one would look better.
Old 01-12-2017, 01:14 PM
  #34
ragtopz28's Avatar
I'm sure you've done your research but, I'm surprised you didn't go with the tried and true NW...
I'm as tight as the next guy, but there are just some things I don't skimp on.
How tight you may ask...."so tight that if you pulled #2 monofilament through my butt it would squeak like a cheap violin"
Old 01-12-2017, 03:15 PM
  #35
I've talked to several guys running them, and read reviews from quite a few others, and they all have nothing but good things to say about them. Plus, the guy who tunes my car said he's tuned a bunch of cars that run the cheap e-bay TB's, and he's never had an issue with tuning even the cheap e-bay ones, which are not near as good as the WARR TB. I'm going to give it a shot and see how it goes.
Old 01-12-2017, 06:01 PM
  #36
ragtopz28's Avatar
10-4 ( I figured you did thorough due diligence). If it works out good then you have $200 to put toward something else
Old 01-13-2017, 08:49 AM
  #37
I refuse to pay $350+ for a hunk of aluminum with a ******* blade in it. There is NO REASON a cable driven LS style tb should cost double the price of a carburetor which has many moving parts and various pieces. IMO it's pure exploitation.
I have a Ballistic Speed 92mm on my car and it's insanely better than the Fast 90mm tb it replaced due to the Fast having an incorrectly sized IAT passage. IIRC I paid $150 for the Ballistic Speed. Sadly they are no longer in business. Heard good things about the Warr tb through, could be made by the same manufacturer.
Old 01-13-2017, 08:54 AM
  #38
moekluse's Avatar
I painted my ls2 manifold wrinkel black and it turned out amazing. Especially with the red anodized fuel rails. Came out super clean.
Old 01-14-2017, 03:22 PM
  #39
If I'm planning in reusing my fuel rails and injectors that are currently on my LS6 intake, would it be best to leave them attached to the intake when I remove it? Then once the intake is off, I can remove them and injectors and put them on the new FAST intake.
Old 01-15-2017, 01:21 AM
  #40
wph351's Avatar
Wow that looks pretty good in red. I always thought these style intakes were best left black, but I'm now rethinking that. Nice job.
On a side note, have you bolted a throttle body up to it yet?
I ask because I just bolted a Nw92 onto my fast 90 and some of the TB to Intake o -ring can be seen through a gap on the bottom side of were the flanges meet.
Anyone else experience this?
Quick Reply: FAST 90 Porting??
