Clash of the Titans - Mamo MSD Airforce vs Mamo Fast102 - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 01-08-2017, 10:00 AM   #21
Love the write up. Read you build thread too.. Awesome work for sure.. Detail on everything made it worth reading the bazilon pages
Bentuna is offline   Reply With Quote
Old 01-08-2017, 10:24 AM   #22
Darth_V8r's Avatar
Quote:
Originally Posted by AINT SKEERED
Its an f14 futral grind but this think loves rpm.]
Thats through a 200 4r transmission with 4600 stall and 4.10 gears in a 12 bolt with 33 spline axles
Combo is a lq4 sbe dart 225s touched up but not not ported and 60 cc Chambers for 11/1 compression cometic .045 gaskets. F14 cam, fast 90 ported by futral . It did 460 speed density but went back to maf as i have a dry nitrous kit.
That thing does rev good! You're peaking around 6700 it looks like, but carrying nicely. 460 is a great number through a stalled auto! You'd be 480+ through a manual.
If you do get the MSD, read Tony's post below about how much material he removes. There's another thread where he took someone else's ported MSD and had almost 90% of what he removes from an out of the box part. You gotta go through Tony if you want it to breathe
Darth_V8r is offline   Reply With Quote
Old 01-08-2017, 10:25 AM   #23
Darth_V8r's Avatar
Quote:
Lol! Thanks! At heart I like research and this build has been a very fun project for sure!
Old 01-08-2017, 12:45 PM   #24
AINT SKEERED's Avatar
I was planning to go through him if i do. My house flooded in August so car is on hold for now . Just no time to work on it but i do research while at work to what i want to do with it. June is probably when i will make the changes.
I wonder if he would be interested in doing some work on my darts abs matching them up? Then do a llsr similar to yours as it has to drove good but pull up top
AINT SKEERED is offline   Reply With Quote
Old 01-08-2017, 03:11 PM   #25
SoFla01SSLookinstok's Avatar
The info much appreciated Darth.
SoFla01SSLookinstok is offline   Reply With Quote
Old 01-08-2017, 07:53 PM   #26
sillysspeed's Avatar
Good stuff!!!
sillysspeed is offline   Reply With Quote
Old 01-08-2017, 08:47 PM   #27
Firebirdmuscle's Avatar
Very nice darth. Thanks for sharing this info. I may have to pick up a msd afterall
Firebirdmuscle is offline   Reply With Quote
Old 01-08-2017, 11:25 PM   #28
Detoxx03's Avatar
This is such a badass write up. Thanks for all of your time and effort.
Detoxx03 is offline   Reply With Quote
Old 01-09-2017, 09:44 AM   #29
So now that you've driven it, tell us how fast does this thing rev? When you have traction of course?
jhshnh is offline   Reply With Quote
Old 01-09-2017, 10:43 AM   #30
Darth_V8r's Avatar
Sorry to hear about your house! Dude, I've been so happy with the LLSR, I might do it on my suburban and see how that goes! You'd have to talk to Tony about the port matching, etc. I just sorta call him and go with his recommendation.
If you're interested in cam thoughts, if you did a 233/241-115+2.5, after it warms up (gains 0.010" lash), it'd be a 228/236-115+2.5, IVC at 46.5 degrees, and only one degree of overlap. Should drive nice and rev nice. The loss of overlap would hurt power a bit, but you'd gain so much more from valvetrain stability of the solids.
Quote:
Quote:
Originally Posted by sillysspeed View Post
Good stuff!!!
Quote:
Quote:
Thanks guys! it was definitely a fun test to do!
Quote:
It revs quite well. It's really snappy. sometimes, that very first hit at 2000-ish RPM has a slight lag, but that was on both intakes. After it's revved the first time, it almost "jumps" to RPM. I had to raise my limiter to 7500 to avoid hitting it. A first gear rolling hit, with traction, 3000 to 7000 is crazy
It's a bit of an adjustment to learn to drive with peak power at almost 7000 rpm vs the normal 6300-6500 you typically see. Cause you never really feel the power fall off or fade. I shifted before at 7200, and I could ride it further, but it felt like it was falling. Now I'm thinking to put the shift light at 7400.
I attached an in-car vid (ignore the tach, it stops at 6600) and a dyno clip. Dyno clip went to 7400. The in car vid, I short shifted, because I hadn't tuned the top RPM band yet.
Old 01-09-2017, 10:59 AM   #31
Can't get the videos to play
Old 01-09-2017, 11:17 AM   #32
Darth_V8r's Avatar
Theyre working fine in Chrome for me. I just double checked. PM me an email address, and I'll shoot them your way. No Charge
Old 01-09-2017, 11:37 AM   #33
z28241's Avatar
Darth, Once again you have research well conducted and attention to all the detail! My setup is 8 years old(starting with the Cam in sig), and even though mines been a constant work in progress, threads like this our encouraging to head back to the drawing board and start all over ..
z28241 is offline   Reply With Quote
Old 01-09-2017, 12:37 PM   #34
Rise of the Phoenix's Avatar
Very nice and informative write-up Darth. Sounds like being the referee for this fight wasn't very easy.
Rise of the Phoenix is offline   Reply With Quote
Old 01-09-2017, 01:28 PM   #35
scotty2000ss's Avatar
Great thread man!
How much for the FAST??
scotty2000ss is offline   Reply With Quote
Old 01-09-2017, 01:46 PM   #36
Darth_V8r's Avatar
Quote:
It wasn't. At first I had a tough time calling it. In the end I feel the MSD better matched my specific build.
Quote:
Originally Posted by scotty2000ss
Great thread man!
Lol!! I've got enough leftover parts to build a decent budget motor, so for now I'm not selling it.
Old 01-09-2017, 02:55 PM   #37
So I wonder what flywheel hp is? 575?
Old 01-09-2017, 03:18 PM   #38
Add about 20% to the rwhp numbers.
Old 01-09-2017, 03:35 PM   #39
Quote:
That would be 622 hp. I would think his drivetrain is more efficient than a 20% loss.
Old 01-09-2017, 03:49 PM   #40
Darth_V8r's Avatar
I been using 15% for driveline losses. I know a 9" is more parasitic vs a ten bolt, but I did have the gears micropolished, and also in the tranny, and a T56 is pretty efficient at transmitting power. Be cool if it was less than 15% parasitic loss, but I doubt that's even possible.
Might sound odd to say this, but I really don't care if the motor makes 700 and loses 35% through the driveline. It's what gets to the ground that matters most to me.
Related Topics
Thread Thread Starter Forum Replies Last Post
2002 z28 Camaro twin turbo 67mm, 1600hp capable, $18k chrs1313 Parts Classifieds 1 Yesterday 10:08 AM
Twin turbo 67s, 1600hp capable setup, 02 Z28 chrs1313 Vehicle Classifieds 7 Yesterday 10:07 AM
LOW MILEAGE LS1 & LS6 Short Blocks under 60k 04 GTO LS2 Style Rods 24X wheel CLEAN N/A86 Parts Classifieds 8 03-23-2017 11:54 AM
Mamo MSD arrived!!! 98_WS6_M6 Generation III External Engine 83 02-25-2017 09:02 PM
102mm Aluminum LS1 intake / throttlebody xssive Parts Classifieds 9 02-20-2017 07:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
