Speed Engineering True Dual Exhaust Kits!!
#81
I think that kind of sounds like **** but that's just my .02. I do think this is one hell of a deal because you change the mufflers many times over and still be ahead. I bet a bolt on car would sound much better. I think my Borla sounds like **** but it makes great power and that's the main importance.
The following users liked this post:
Z28_Demon (07-18-2019)
#83
That looks like it tucks up nicely! Should be even a little better with the strains. Do you have any rubbing or banging? Did you have to cut or remove the tank heat shield?
#89
Ugh. This is how I wanted my car to sound when I made my true duals. I put pypes m80 mufflers on and its so quiet I have to get on it to kinda hear it. Everyone tells me its extremely loud, but not inside the car where I wanna hear it.
#94
You guys could easily make a cheaper version of this using the Hooker mild steel straight through 4" muffler...
https://www.mufflex-performance.com/...lowmaster.html
Hooker muff..
https://www.summitracing.com/int/par...9hkr/overview/
Priced at around $500 and put it on eBay so I can use their global shipping.. i'll buy one straight away !
Hooker muff..
#100
I bought the rear exit kit and have had a few issues, which is almost to be expected when it comes from China.
My package did not contain the passenger side exhaust tip, packing list of materials, or clamps that are worth your time. Speed Engineering will, hopefully, replace the missing tip and I am buying 9 stainless band clamps to replace the junk pieces in the kit.
As mentioned earlier in the thread, you will need to grind down the washer for the rear-most hangar brackets to fit.
On the bright side, it sounded pretty good for the 50ft I drove it out the door of the shop.
