Plugs and Wires Replacement
Old 03-02-2017, 05:37 PM
KonkeyDong's Avatar
Default Plugs and Wires Replacement
What is the best way to reach the dreaded #8 spark plug? Ive changed my plugs before on another car, but left the 8th because I couldnt reach it! Was able to replace the wire, though.
Ive read about cutting a hole in the firewall on the passenger side interior. Also read about using a bunch of extensions/swivels. Ideas?
I have a misfire code and also a low idle/startup issue when the engine is warm, fires up first or second try everytime cold. When warm itll idle really low for a second sometimes upon startup.
Kind of concerned about it not starting up first crank also. Sometimes it takes a second and sometimes I might have to return to off igition and crank again.
Old 03-02-2017, 06:35 PM
volsfan32119's Avatar
I removed the coil packs and was able to get to it better. It's still difficult but I was able to do it. Good luck!
Old 03-02-2017, 06:42 PM
KonkeyDong's Avatar
Awesome. Im thinking I may just do this when I change my headers, if I can find an affordable set of headers and y pipe, o2s, etc.
Old 03-02-2017, 10:13 PM
jlangley's Avatar
I got mine from below. Had to kind of bend the heat shield a bit and force my arm up there. Looked impossible at first but once I got my arm in there it wasn't that bad. Definitely the hardest one!
Old 03-02-2017, 10:20 PM
wannafbody's Avatar
Easiest way to change the plugs is to change the heads.
Old 03-03-2017, 12:21 AM
OLDWS6's Avatar
From underneath using a socket and an open end ratcheting box.
Old 03-04-2017, 02:12 PM
BandDirector Blk98ZM6's Avatar
Loosen the coil pack bracket at the rear, take the bolt all the way out on the front and slide the bracket up. On '98's remove the #6 and #8 coil packs completely. I climb up in the engine bay, put my knees on top the battery, and go in after it. I can do all 8 plugs in 30-45 mins, but it usually takes just 20 mins. on just #8. Gotta be patient...
Old 03-04-2017, 02:19 PM
LS6427's Avatar
And when you get it out.....put the new spark plug in just hand tight.....then a small little snug with the ratchet. Next time it will come out easy.
Old 03-04-2017, 02:54 PM
firefighter34's Avatar
2 ft of extensions with a swivel on top! Enjoy! Just put mine back in.
Old 03-04-2017, 04:12 PM
Darth Cypher's Avatar
#8 was pretty easy for me. I had my car on ramps and replaced it from underneath. It was tight but was much better than from the top in my case. I also used a ratchet that swiveled on the top. Just like the one in the image below.
Quick Reply: Plugs and Wires Replacement
