Conan steam pipe routing
Old 08-30-2014, 03:06 PM
97ss497's Avatar
Default Conan steam pipe routing
Installed conan's stuff he referred me to; the pipe in the back is GM part #12605716. The front steam vent is an LS6 tube. The 3 tube fitting is here:
http://www.chicompany.net/index.php?...68a08e042e8a7e
I've got to add clamps yet; should be a real nice looking setup and functional too.
Much appreciated conan!
Old 08-30-2014, 07:23 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Lookin good!
Old 08-30-2014, 09:52 PM
conan's Avatar
Engine looks bad ***, liking the intake. Glad I could help out with the steam vent plumbing.
Old 08-31-2014, 12:55 AM
99'CajunFirehawk157's Avatar
Thumbs up
I did something very similar, note the black rubber hose at the bottom of the pic by the power steering reservoir going into a "T"...BTW who did your hydro?
Old 08-31-2014, 07:23 AM
97ss497's Avatar
Pat from Baytown Texas, he does great work.
Your engine compartment looks sick!
Old 08-31-2014, 01:12 PM
conan's Avatar
Make sure to have the rear hose on and clamped before you put the engine back in the car. I forgot how tight it was back there and had to pull the intake manifold off to hook up the rear hose
Old 08-31-2014, 08:34 PM
97ss497's Avatar
This motor is going in my 70 Camaro, lots more room then a 4th gen :-). Plus I have the whole front clip off.
Old 09-01-2014, 07:59 AM
conan's Avatar
Cheater
Old 03-13-2017, 07:29 AM
BennyB's Avatar
Figured I'd bump this thread bc I wanted to know if anyone has tried this with a fast 102 intake manifold and whether or not it works?
Old 03-13-2017, 03:15 PM
Paul Bell's Avatar
I can't imagine why these lines would not work.
Old 03-15-2017, 01:43 PM
conan's Avatar
Do you have the fast 102 on you car currently ?
Old 03-15-2017, 11:55 PM
BennyB's Avatar
It will whenever Maryland Speed gets it shipped
Old 03-16-2017, 02:57 PM
conan's Avatar
The rear pipe should fit fine with it going on the out side of the oil pressure sending unit. I haven't heard of the crossover pipe in the front hitting the fast intakes so you shoud be fine there too.
What coolant pipes are you running currently ?
Old 03-17-2017, 01:47 AM
BennyB's Avatar
Ok sounds good and thanks for your input. I'll be using the stock LS1/6 front coolant pipe and in the rear I'll be using the 12605716 pipe that's pictured in this thread.
Quick Reply: Conan steam pipe routing
