Remote Oil Filter Mount with Thermostat
LS1Tech Sponsor
Improved Racing just launched a remote oil filter mount with a built-in thermostat. If you want to run a remote filter and a cooler, this will save you space and cost!
An oil thermostat is critical for any vehicle running an oil cooler and driven on the street. Without it, your oil may never reach operating temp, resulting in premature engine wear and damage.
The filter mount is available with a 185F or 215F thermostat. It has female -10AN ORB ports with optional adapter fittings for -6AN, -8AN, -10AN, or -12AN lines. It can also be used with transmissions.
The large M22x1.5 filter thread accepts a large number of filters in many different sizes. It also includes a mounting bracket for multiple mounting options.
Here's a list of some compatible filters: https://www.improvedracing.com/manua...-reference.pdf
More info here: http://www.improvedracing.com/oil-fi...tat-p-781.html
If you also need an oil filter take off, we have them available as well. LS engines made up to 2006 will require the 13/16"-16 filter takeoff. 2007 and later, as well as any new oil pan purchased after 2007, will require the M22x1.50 filter takeoff. More info here: http://www.improvedracing.com/oil-co...ate-p-644.html
