Switched power block?
Hey guys and gals. I'm in a pickle here and hoping someone can help out. I got a 10 way power block that I want to use to tidy up wiring. Was planing on hooking up constant power from battery, alt., interior constant fuse things to the block but I need a switched block as well.. boost solinoids, ecu (while cranking) and fans so far. Any way to get a relay or something that is big enough to support all the switched items. Don't want to keep slapping all my switched sources with new stuff one by one and for sure don't want to splice all my new switched sources to one 16g feed.
Option two.. all my constants go to the starter solenoid with Costa battery power and my switched power gets fed from the old fuel pump wire feeding the block. Can't imagine relayed fans, boost solenoids and the switched part of my holley efi would pull anything substantial.
What I've got.
92 Mustang lq4 swap with boost and meth. Holey efi ecu.
What I've got.
